Peer81
Vacuum sensor line to carb
Hello everybody,
I'm looking for pictures how your plastic vacuum line (from the vacuum sensor) is connected at the back to the rear base of the carb. Mine has a 1.5" rubber line that connects the plastic vacuum line to the vacuumport at the rear base of the carb. It's very easy to move the plastic line in and out the rubber one and as the vacuum sensor should sense the difference in vacuum from the manifold I think it's important that there is no vacuum leak between the rubber and plastic line.
If somebody has a different (original) connection I would like to see some pictures to do the same. I was thinking to epoxy the plastic line in the rubber line to get rid of any vacuum leakage.
Greetings Peter
Hello everybody,
Greetings Peter
