yep, don't even bother trying to repair those paint chips because the touch-up paint wasn't original
Vettehead Mikey said:The key is what the car (or engine or component) APPEARS to be at time of judging. If there is no visible clue that the engine is not the factory original one, then no deductions are taken. Keep in mind that the inspection is merely a visual one, no DNA or urine samples are taken :L.
If the VIN stamp is obscured/gone, or is not typical of factory production, including it not agreeing with the car's VIN then the appropriate deduction is taken. 'Wrong' or absent or bad restamp are all considered the same thing, same deduction amount.
Same applies to the engine plant stamp and the broach marks. This part is only judged after the casting number and casting date is judged.
GerryLP said:In addition to this, some engines broke while still in the warranty, and some of those vehicles got a factory replacement engine, so if the new replacement does not have the vin stamped, and yet the paperwork properly documents the engine as a factory replacement, then this suffices as far as documentation. Doesn't it?
GerryLP:cool
