The73vetteman
I had the heads on my L48 rebuilt last winter and then i put the motor back together myself (reusing the rocker arm stud nuts - this may be significant - read on). It ran but I had a little trouble with it spitting back thru the carb. I checked the valve lash (by turning the push rods) and found play in most of them. I tightened them up and it ran ok.
Now, maybe 200 miles later, I'm getting the same symptons again - spitting back once or twice coupled with distinct 'tap tap' sounds from the engine when cold. I'm thinking that the lash has opened up again and I think I remember reading that the nuts securing the rocker arms can work loose.
Does it sound like this is my problem, and if so, any tips for how to secure the nuts in place? If I just need to buy new, any suggestions for a source?
Thankin' you in advance,
'73
'73
