DURATION: Duration is how long the cam holds the valves open. It’s expressed in degrees of crankshaft rotation (remember, the cam rotates at half the speed of the crank). A 280-degree-duration cam holds the valves open longer than a 260-degree-duration cam. Holding the valves open longer allows more air and fuel into the engine and also allows more to get out through the exhaust. Longer duration (higher number) improves top-end power but almost always sacrifices low-end torque. Lower duration improves low-end torque and makes the car idle better, but it limits top-end power, and you can get only so much valve lift with a short duration cam due to the rate-of-lift limitations of the lifter. Roller cams have the advantage of allowing high rates of lift with relatively short duration.
The confusing thing about duration is the difference between “advertised” and “at .050-lift” duration. At .050-lift duration is measured from the point where the cam moves the lifter up .050 inch until .050 inch before the lifter is all the way back down. Most cam manufacturers differ in where they start and finish measuring for advertised duration. Some start at .004-inch lift, some at .008-inch and some measure it somewhere in between. That’s why the .050-lift numbers are the best to go by. A 280 cam (advertised duration) from one manufacturer could actually have less at–.050 duration than a 278 cam from another, due to the different points at which the companies measure advertised duration.
LOBE SEPARATION ANGLE: This is the relationship between the centerlines of the intake and exhaust lobes. A 110-degree lobe separation angle means that the peak opening points of the intake and exhaust lobes are 110 degrees apart. This is ground into the cam and can’t be changed without changing cams. Lobe separation angle is another way of expressing overlap, which is the term formerly used by cam manufacturers. Overlap is the amount of time that both valves are open in the same cylinder. When both valves are open at the same time, cylinder pressure drops. A cam with 106 degrees of lobe separation angle will have more overlap and a rougher idle than one with 112 degrees, but it’ll usually make more midrange power.
DUAL-PATTERN CAMS: A dual-pattern cam is one that has different duration and/or lift specs for the intake and exhaust. Usually, the exhaust lobes have more duration and lift than the intakes. Depending on the engine, this can be beneficial for engines with poor exhaust-port flow or otherwise-restricted exhaust systems.
