My VATS drove me crazy too long...I beat it on my own terms! First go to TBI power chips and get a reflashed memcal prom, Deleting the VATS program (cost about $75.00) this does away with the fuel pump and injector pulse problem. Then drop the driver column cover and find the relay with the large yellow wire and the large purple wire, cut them at the relay and butt connect the two of them together. That takes care of the starter interrupter relay problem! Then throw away the remote control and lock your doors when you want! CAVEMAN STYLE....
Yes but you need to know the resistance of your old key resistor pellet so you can install the correct value resistors into the VATS wiring
Get a new key cut with the correct resistor pellet to suit your new lock barrel ; blank GM keys are available; with the 15 different resistors
GM VATS Key Blank Single Sided Cadillac Chevy Ponitac | eBay
all you need to know is which # key you need
Read
VATS and PASSKey Vehicle Anti-Theft Systems - ThirdGen.org
Some locksmiths can read the old key for you ( and have the new blank keys ) , otherwise you will have to measure it yourself with a DVM
an easier way i just figured out this afternoon is using a variable pot. i found one that covers the first four combinations. i just soldered it to the original cylinder plug, sounds easy enough, yeah right. i'm trying it tommarrow. wish me luck.Options
Get VATS deleted on the tune
VATS Delete Chips
Or buy a signal generator for the fuel enable signal required by the ECM
Baker Electronix - GM VATS Bypass
Either of above require manually bypassing ( or deleting of ) the starter enable relay.
VATS gone for good
Fitting the resistors keeps VATS intact , just fools it into thinking the correct key is in the Ign
Makes the system useless as a security device and still leaves the VATS module and starter relay as future fail points
Requires you to make up and try the 15 resistor combinations until you get correct one for your car
ecm outputs +5v and must see this output ''grounded'' at 30 hz (continuous ground will not work) before the ecm will ''pulse'' the fuel injectors...you can eliminate the ign key resistor, vats module, assoc wiring by sinking (grounding) the ecm output (86-89 ecm pin B6, white wire, other years vary) into a simple 30 hZ gen.
i used the ''venerable'' 555 ic chip with resistors, capacitors to do it (plus a transistor to sink, as the 555 supposedly can sink directly but i haven't figured that out yet)and diodes to assure no backfeed/damage to the ecm...my concoction has three wires leaving it, which tie into existing wires at the ecm for +12v/ground/ vats +5v output.
was into solid state design long ago, still newb with internet, can't scan /post the schematic...last time i said ''freebie'' on the net i got 2000+ requests, never again(you do the math)...for a minimal donation (very minimal,whatever you think correct, i have no desire to make a profit and then need to deal with the feds re taxes) to cover gas/photocopy/ mailing i will be happy to send you the schematic/raddyshack parts list to do with as you please --post here, mfg,etc.
there was an on-line vendor (still ?) that sold the device, apparently also 555 based, but in a plastic housing with a red LED (oh wow) for abt $50, if you're not into making a little solder smoke...i can't recommend them as i never bought one,tho.
btw, you can check if the ecm/ vats output is properly conditioned by checking voltage on that wire from ecm pin B6 with a digital VOM, abt +2.5 volts means go, 0 or +5v will result in a ''no injector signal'' at the ecm/injector pins.
