nylben
1998 Mystery Car
I have a 1998 with 54k - was running fine when I drove her last week. It was parked in the garage with the top down and I went out to take her out for a drive three days later, I hit the starter NOTHING, the starter did not engage, as if it was a totally dead battery. I received the following on the display: "Reduced Power, Check Tire Monitoring System, Service Engine Soon, Low Fuel". I pulled the codes from the DIC and have the following:
10 -PCM - P1518 PCM to TAC Module Processor
40-BCM- Body Control Module - No COMM
60-IPC - U1040 - Loss Of Communication with TCS
60-IPC - U1160 - Loss of Communication with LDCM
60-IPC - U1176 - Loss of Communicaton with RFA
99-HVAC - No COMM
A0-LDCM - B2284 Battery #2 Fault
A0 LDCM - U1064 - Loss of Communications with BCM
A1-RDCM - B2285 Battery #2 Fault
A1-RDCM - U1064 Loss of Communications with BCM
The only thing out of the ordinary that I tried a couple of weeks ago was to install a Jet Performance Chips Power Control Module (PCM). When I installed it and tried to start the car I received similiar codes, so I removed it. After clearing all the codes and starting the car it worked fine until this. Does anyone have a similar experience? Does anyone have a solution based on this information? Do I need a new BCM - PCM - ?????
PLEASE HELP!!
99-HVAC - No COMM
PLEASE HELP!!
