Hi All - My new '07 C6 has a vibration which starts at 65 and gets slighty worse as I go faster. It has been to the dealer 3 times. Work done as follows: 1. Rebalanced Tires; 2. rebalanced again and "re-indexed" front right tire; 3. Installed new tire on right front. [On the last dealer visit, they said the right front had excessive road force. Measurement before tire replcement was 32 lbs. Spec is 26. Indexing would not give any correction].
There has been zero improvement with this work. A friend says the run-flat tires might be the cause. He had the same issue and replaced the EMT's with regular tires, and the vibration went away.
Any advice???
Thanks!!!!
Any advice???
Thanks!!!!
