vibration in transmission
  • Thread starter Thread starter stingray71
S
stingray71
Please help
I can't get what I whan't from my LT-1 machine
because when I speed up the engine it vibrates in the transmission ,I've changed the harmonic balancer.Even when
I speed the engine when the car stands still the problem is
there.:confused :confused
vibration
Problem might be in the clutch, more exact the flywheel may be warped or out of balance?
these problems can be hard to track down, but clutches are fairly inexpensive and the clutches available now are SO much better than the originals.
good luck
Gus
webmaster for the
www.lt-1registry.com
stingray - did you ever determine what was the cause of your engine vibration?
Just changed the HB and it improved, but the vibration is still there.
Shawn
