TWINRAY
- Joined
- Jul 24, 2003
- Messages
- 451
- Location
- Long Island, NY
- Corvette
- '67 Goodwood Green Coupe, '69 Lemans Blue Roadster
First off, the car has been off road for 4 years. I have a 2002 battery in it that's been on a Tender all the time. I know I need a new battery when the car gets on the road especially if it doesn't power up the motor when I try and start it - which hopefully will be in the next few days.
I put a voltmeter on the battery this am and it reads 13.2 volts
. I then put the battery disconnect on power, the only draw is the 2 under front dash panel courtesy lights, and the voltage drops to 7 and change
I check the "switched" pink wire on top of the steering column that goes to the ignition - it's also on 7.2v when switched.
I go to the starter input "heavy wire" terminal and it reads 13.2 volts.
How can that be
How can that be
