65stinger
I have a question about the location of these Volt. Reg's. I was reviewing the wiring Diagram for the engine in my AIM lastnight for an upcoming new wiring harness when I seen on the diagram a picture of the Reg was on the same side as the battery (which I assume means on the fender well on that side). BUT, if you read the specification and locations of the Battery and Voltage Reg. in the front of the AIM, it specifies on the opposite side of the battery. Can someone tell me which is correct? I'm sure the new wiring harness will be able to dictate the location by the length of wire provided, but I'm still curious as to what is SUPPOSE to be correct.
