TimAT
Sounds like a "toe-in" problem....
The front-end shop may not have set the toe (around 1/8" toe-in) if there is no toe-in the car will want to wander all over the road. Have a front-end shop check it before you spend a lot of money.
This is the FIRST place to look, (past your old tires). If the toe is set less than 1/8" it will make the steering feel "twitchy" at speed. Kind of re-defines sensitive.
I had a very similar problem with wandering when I got my car. The first thing was taking almost all the "slop" out of the steering box with the adjustment screw on top. Be careful, and tighten it slowly until you feel just a little resistance. Too much starts ruining the internals in the box. when you feel just a little resistance, stop and turn back 1/16 of a revolution or so. I had to do this three times to find "The Spot", but the car handled great after that. If you tighten the screw too much on a non power steering car, you will notice increased turning effort immediately. On a power steering unit, it's not as evident. That's why you need to be careful.
The other thing is to look at is the front end bushings on the a frames. They are probably shot, just from sitting. Replacement is probably needed if they are 20 years or so old.
The proper way to adjust a steering box is with a torque wrench and the procedure in the shop manual. If it's adjusted by "feel" there's a really good chance it'll be too tight or too loose with the same result. Destroyed gears. Too loose and the gears get hammered by the excess slop. Too tight wipes them out.
