silverstreek
A recently purchased 93 Corvette has a few issues I've been trying to resolve. One issue is when turning the heat on, I've noticed cold air blowing. I've also noticed the AC compressor is running. I did disconnect the compressor to see if this was the case where the AC was over-riding the demand for heat. I also checked the heater hoses to make sure I had flow, and to also make sure there were no blockages. They both seem to be hot, but still no heat coming from the floor, defroster, or vent duct work. I'm wondering if anyone has run into this problem before?
I also have an issue with the coolant temperature gauge not working. The signal to the instrument cluster showing the coolant temperature in degrees works fine. While researching this I did read where some of the earlier coolant temperature sending units were defective after a while because they leaked internally causing a gauge malfunction. Has anyone heard of this before?
What I don't want to do is throw parts at any of these problems. That gets expensive, and sometimes you don't know what the original problem was, or why it happened in the first place.
Any help or suggestions would be greatly appreciated!
Silverstreek
Silverstreek
