The73vetteman
Well I've gone from intermittent stalling so frequent stalling to not starting at all, so I need some help!
Here's what I've done/checked:
Cranked the engine while holding #1 plug lead to ground and observed a spark.
Checked the static timing as best I can with a dwell meter - seems that the points open at about 12 deg Before. (Turning the engine over by hand also verified that I'm getting compression.)
Removed fuel bowl (Holley 4150 carb) and blew out jets and idle mixture passageways.
Checked all the vac hoses are in place, and cleaned out the PCV valve.
So as best I can tell, I'm getting fuel thru the carb, and a spark at the right time. All I'm left with now is bad gas OR water at the bottom of the tank. I've refueled twice since this problem first started to appear, so I'm left thinking maybe there's water in the gas.
Any suggestions or ideas?
John
John
