Prisonman
How does one identify what carbs i have on my 61 2x4-Is it marked somewhere?
Once I know what i have where would I place the ID tag. Thanks
I took a look and both carbs have 1299 marks on them! Would those numbers convert over to the MFG# OF frt 2626S AND rr 2627S?vintagecorvette said:There should be a little brass triangle tag with a date and number stamped into it no the top. But many go missing over the years. There will also be numbers cast 1299, or o49 into the air the body, base and air horn. Have a good look. Post what you find. oWEN
