R
robare
I recently purchased a 95 ZR-1 which has a bad hatch seal. The weatherstrip appears to be manufactured an inch too short in both directions , and has come apart in one corner. The rubber seal has also broken free of the continuous plastic "U" clip which holds the seal in position. I removed everything and found no use of weatherstrip achesive, but I did find a yellow grease-like substance inside the c-clip.
I purchased an aftermarket weatherstrip, and it too appears to be short about the same amount. HELP!
