Boomdriver,
I feel your pain (or is it pleasure). With the Lone Star kit I got this car is tight. Women have to be encouraged to close the door with vigor or it doesn't close entirely due to the competence of the seals. Even with all the noise I allowed with the chambered exhaust (damn noisy but very nice) I get reduced noise in the cabin when I roll the windows up!
No leaks. Used a little 3M weatherstrip adhesive put on both the seals and the seal surface (applied with a dope brush form Lowe's) and they don't move and have stayed put since installation.
After rereading my posting above I did remember what might be a negative. The weatherstrip kit has a smell that is not unpleasant but pervasive (chemical odor). After some weeks of expecting it to dissipate I washed it with soapy water. Smells were reduced about 95%. After I washed it off I found the stickiness of the seal a little much to let my passenger window roll up all the way to the top. I presumed the prior slipperiness (before washing) was a byproduct of whatever they used as a release agent free them from the molds during manufacture. So I sprayed some silicone onto a rag and wiped it down. Worked OK for a couple weeks. Got difficult again. Then I figured out that the Black Magic gloss fluid that one uses on the blackwall on the tires has much more viscous properties than aerosol sprayed silicone. Be a little generous and after an hour wipe off the excess and you cannot get it onto your clothes or even to leave a mark on the window. Hell then wipe it on your tires!
Now to defend the seals (and justify not fixing the window right now), I know the motor for the window is weak and I need to replace it but I am awaiting a hard failure before replacing it.
Again, you cannot go wrong with this company! They are good folks to talk with and more importantly they do what they said they would do, when they said they would do it!
Brian Smith
Flower Mound, Texas
