S
sscam69
I have stripped the heck out of a bolt on the intake, actually its an adapter, for the temperature sensor.
Well I tried using a wrench and that pretty much stripped what was left of the adapter and my final shot was to use a monkey wrench hoping that it would grab the bolt and I would be able to unscrew it loose. No such luck. I forgot how soft brass is and just made it worse. To add on top of that I can't screw in the temp sensor back in because it is now deformed. Now I can't drive my car
This could not come at a better time though. I have to check the timing of the car along with a few other details and this would provide and opportune time to fix all this stuff over a weekend.
Another thing. I bought a painless wiring harness for my electrical fans. What I love about it is the temperature sensor is it bolts into the intake or the heads depending on your preference. Well now that I have two sensors (temp gauge as well) I need two places where I can bolt them in, and I screwed up one of them.
I remember on a previous post that someone mentioned that the Weiand intake performed just as good or better than the Performer RPM and did not have clearance issues.
My question is which Weiand intake is it? The stealth? Action Plus?
Thanks for any help
Thanks for any help
