DeanW
Is any one running this intake? It is advertised as from idle to 7000 RPM.
Will it fit under a stock small block hood??
The manifold should match the cam and your optimum power band. Figure out where you want that to be and what cam you are going to use to get there first. It is a good manifold but you need to be sure to match your intake, cam, carb to what you expect the engine to do and how you will drive the car, i.e., drags, top end, stoplight to stoplight, etc. I had a 425 HP engine and it never saw above 6,500 rpm. Turned 11.99 in a qtr in a 3,200 lb car. Do your homewrok before you spend your $$. Things like rear end ratio, weight, type trans, tire size, all play a roll in setting up the optimum street car. Not saying you shouldn't get the Stealth, just be sure the direction your heading.DeanW said:Thank you for the welcome. Don't know if I'll ever get there either, but, I want to build the motor to about 425 HP. Idle to 5500 wont cut it.
