81 Corvette
Since everyone is having them, i thought i would toss mine into the fray.
It seems to be coming from the rear. It sounds like as the wheel turns that something is hitting something in there. Its sounds kinda like if you took a chunk of metal and held it agaist a j-joint as it the joint turned. smack smack smack. no squeak or sqeal. Also, this doesn't happen all the time, but when it does, its only under accelleration hard and soft. Never coasting or braking.
Could the ebrake becoming apart? When i pull the handle in the car, it has very little resistance and doesn't slow the car down. Could the calipar be going, then allowing the pads to do things they shouldn't normally be doing?
Any help is greatly apprieated.
