vigman
Motor head!!!!
- Joined
- Feb 13, 2001
- Messages
- 3,471
- Location
- Valencia, CA,USA
- Corvette
- 88 Convert ( SOLD ) /1973 coupe 4 speed/1964 Vert!
So while getting everything ready I pulled out all the valves today & de carboned the head.
I found a WELD inbetween the intake & exhaust.
Now looking at it I panicked.... but I continued on.
My neighbor Kevin the welder looked at it and identified the weld spot as Nickle.. but they didn't do a great job cleaning it up.
The area in question is from the flat spot down into the V between the 2 valves, but the seats look undammaged.
It looks like at some point the intake valve dropped and got mushed back into the head.
And this is how they repaired it.
Kevin did a little grinding on it, and it looks better.. but suggested I had it redone..VIA a TIG welder ( which he didn't have)
Any thoughts..pix on the way..camera charging.
BTW how do you tell what type of seats you have.. the valve guides are IRON but really snug ( no valve play side to side).
The spring seat looks SLIGHTLY undercut and there were NO shims.
I am assuming the enging was rebuilt about 2-5000 miles ago.. however the WHEN
(guessing 15 years ago) would still put in in the leaded zone.
Still have not identified the cam ( Not GM )
All the neighbors ran for cover today.
Mike
Mike
