Wet Plugs
  • Thread starter Thread starter Stryker_78
S
Stryker_78
I tell ya if its not one thing then its another. I pulled the plugs and 6 & 8 have oil on the electrodes. Just a bit mind you. The rest of the plugs are all carboned up. They have a mere 1500 miles on them. They are AC Delco Rapid fire plugs.(incase you were wondering) :)
Does all of the carbon mean I am burning too rich? The oil on the 2 plugs means what? Oil rings gone on those 2 cylinders?
Any help would be greatly appreciated. :)
Scott :w
Stryker,
Generally black, heavily carboned, plugs would indicate a rich condition. As to the oil fouling, I would suspect valve seals before I said ring job. You should however do a compression test to verify the condition of the rings and cylinders. A weak coil could also contribute to the black plugs you are seeing.
Thanx for the response Dale. Is the richness adjusted with the 2 nipple type screws located on either side on the front of the carb?
I will get a compression test done aswell. Was thinking of doing it awhile ago actually. :)
As for the coil, it is a new coil rated for 50,000 volts.(pertronics coil)
Thanx again Dale.
Scott :w
The car is finally road worthy. The cleaning of the plugs, new wires and a SERIOUS timing adjustment and it is running just like I expect. As for the timing issue, it was advanced about 30 degrees. Not sure how that haapened. Maybe when I put the new distributer cap on, I might have moved it somehow. Oh well, live and learn.
The wet plugs I figure was from runoff from when I adjusted the rockers with the valve covers off. Man what a mess of oil. :)
Scott :w
