silver00v6camaro
Need some cam input.
350
Vortec Heads
RPM Air Gap Intake
670 Holley Street avenger Carb
9.5 compression
which cam to use?
Comp xe262 Duration @ 0.050" 218 / 224
Max Lift w/ 1.5RR 462 / .469 Lobe Separation 110
Lobe ID#'s 5442 / 5201 Intake Centerline 106
or
Lunati 60102 60102LK 262/268 219/227 .468"/.489" 112/108 Hyd/Hyd 1400-5800
Which would you go with lunati or comp. Any othe input for a good 262 cam is appriciated. Thanks
350
Vortec Heads
RPM Air Gap Intake
9.5 compression
which cam to use?
or
