silver00v6camaro
Does anyone use these heads if so are they good or bad. Here is the combo
355
World Products Sportsman II heads
lunati voodoo cam 60101LK 256/262 213/219 .454"/.468" 112/108 Hyd/Hyd 1000-5500 or
lunati voodoo cam 60102LK 262/268 219/227 .468"/.489" 112/108 Hyd/Hyd 1400-5800
Weiand Stealth duel plane intake and a holley 770cfm carb.
Also if not these heads what are good heads for these cams. I am wanting a street car so any advice on a good hp/tq steet car with this setup would be great. I am going to use on of the lunati voodoo cams and the weiand intake and holley carb for sure just need to know info on a good set of heads instead of the old 882 that are on there know.
Car is a 75 with turbo 400 tranny and 3.08 gears and no i am not changing the gearing. Also what stall will i need.
355
