IH2LOSE
- Joined
- May 24, 2001
- Messages
- 3,908
- Location
- We Will All Meet Again
- Corvette
- 1966,and a 1962 thats almost complete
So I was having problems with the look of the excisting intrument cluster.I seen John McGraws and wanted something different also.
So I purchased some styrofoam and then carved it to the shape I wanted.(I allready picked out my gauges so I knew what my requirements were)
I then painted the styrofoam with a sealer. I then went to my shop and made a small metal box.I then mixed up the plaster of paris and poored it into my metal box (80 lbs of plaster) next time I would make a smaller box and use less plaster but I was afraid it would break if it was not thick.
Anyways I then placed my styrofoam carving in the plaster until the plaster set.
Once the plaster set I removed the styrofoam and smoothed out the inside of the plaster mold with more plaster and sand paper.
I then cut up fiberglass matting into different shapes and screds,mixed up some resen and started laying the matting into the mold.
I let the glass set for a while ,but prior to it getting rock hard I removed it from the plaster mold and allowed it to cure in the sun.
Once it was hard I then trimmed the edges and shaped it some more so I could install it in the car.I bent and welded some mounting brakets and we are allmost ready to drill in the gauges and then the body work needed to smooth it out for paint.
I could not finish my steering column untill I had this peice. Wright now I have to wait untill I get my steering wheel hub.I have the steering colum completely moxed up now with wooden dowels and have to see how it feels with the wheel on.I may want to bring the column back into the car a tad (to lessen the angle of the steering joints.I also may want to lower the colum where it mounts to the firewall because I am worried about how close one of the univerasl joints is to the power brake booster.
I also had to weld a heim onto my frame to support the steering shaft because I had to use a 3 rd joint in the column.
Lastley it does not show up well in the photos but below where the gauges mount there is room for all of the switches and an a/c vent directly under the steering column.
http://members19.clubphoto.com/lawrence748455/2731213/guest.phtml
That will provide a nice touch to the car. Best of luck with the rest of the project.
