Viet Nam Vett
- Joined
- May 28, 2004
- Messages
- 2,410
- Location
- Egg Harbor Township NJ
- Corvette
- 65 BB 502 Cp /MSD ATOMIC EFI/ 2009-HUMMER H2
Syco Babble..!!!
So I Bought the Holley Electric Fuel Pump With the Nifty Difty Pressure Regulator. After out finding out that I couldn't mount it sideways do to the possiblity of it blowing up from a fuel leak into the motor section, I went searching for another pump.
So I ended up speaking with Aeromotive Fuel systems. Sopoke with there tech support and found an entry level inline pump. Mark there tech then told me I have to add a filter between the tank and pump. He explained that I needed a 100 Micron filter ..And was adament that it not be any smaller Then 100 Micron. Such as the one you would use in front of the carb (10 Micron).
He explained that the smaller would cut down the flow at demand and cause the pump to Cavitate...this intern would airate the incoming fuel and cause the pump to overheat and burn out faster not to mention hurting he performance.
After desiding not to by his pump because of price and also that I now needed to add a fuel return line do to the nature of the pump design. This thing is getting way out of hand. It's like the 5 Million Dollar Fuel Pump From hell..!!!!
So I went back to the holley idea. I called Holley and asked them if I needed to use a 100 Micron filter or could I get away with a less expensive filetr ..like a 10 Micon.that has NPT in and outs. They Said that they Recomen using a 100 Micron filter in front of there pump..!! That's Per Tech Support At Holley..!!
The Aeromotive filter is $91.00 plus it uses AN-10 fittings. The Holley Pump uses 3/8" NPT in and out...!!! I need to use Hose Barb Connections to make this thing work easy. No one makes any adapters that easily changes or adapts this filter. Also try and find a 100 micron Filter out there. So far the only one I found in a tubuar shape is the Aeromotive.
Holley doesn't mention anything about this 100 Micron BS in there instruction sheet.
Has anyone out their addressed this issue with there electric pump??
ad
Take It Away BoB
![martini :m :m](/data/assets/smilies/martini5.gif)
Take It Away BoB
