Aurora40
What things to be aware of on a 1990?
So one of the Corvettes I am considering buying is the 1990 ZR-1. I love the old body-style of it. I know there were some changes during the year, and just wanted to make sure I have my bases covered.
I will of course want to check it mechanically and such, but am wondering more about changes and such to the cars.
There were some with manual hvac, and some with iron driveshafts in 1990, correct? The hvac isn't a biggie, but I'd want the aluminum driveshafts (if for no other reason than how awesome a 3" shaft of aluminum looks).
Was 1990 the year they introduced that passive key fob? I thought it was the 1990 ZR-1, but could be mistaken. Was it standard or an option, or am I totally off?
1990 PCM's should have been replaced under warranty for basically all cars, correct?
Do the windshields all have delamination problems? Or are some great and others not? I'm fine with a non-original windshield, but I think another UV one would be nice (newer ones don't delaminate and you can't even see the film).
What kind of maintenance things are a must on the car regardless of mileage? Is the LT-5 sensitive to coolant maintenance? The all-aluminum Premium V8 (Northstar/Aurora) can literally endure or die due to cooling system maintenance. The aluminum engine means the coolant never gets dirty/rusty looking, so it may look clean and new but have all the protection additives depleted, thus leading to headgasket failures and other problems. True of the LT-5, or not so true?
Finally, curiosity: The oil filter upside down on top of the engine... Does oil chug out of that thing all over the place when you unscrew it??
Thanks for any info!
