C
chris1
I ordered one of the low temperature fan switches from Eckler's; I have a 91 without the booster fan option; I haven't received the kit in the mail yet, however there is a metal plug that needs to be removed between the number 1 & 3 cylinders on the driver's side in order to screw in the sensor, and then wire it to the fan relays accordingly. I though I was going to be able to remove it with a standard 3/8 extension form my socket set, however it is too big; does anyone know which kind of tool, and what size is needed to remove this plug? It may say it in the instruction when it arrives, however I was just curious in advance, and their websites' instructions just says to remove the plug......
Thanks, Chris.
Thanks, Chris.
