Nick90vetteguy
wist stock 2.59 gears or 3.05 gears and both mildy modified engines with one with a zz4 cam and another with a stock L98 is there REALLY a difference in performance?
Depends what mods you are talking about.both mildy modified engines with one with a zz4 cam ?
Performance would suffer using a zz4 cam with stock intake and a 2.59 rear end. At a minimum, you would want a 3.07 rear, modified intake and customized prom (ECM).
Refer post # 3does this cam work with with the stock intake manifold/penelum or is the SLP runners a advantage?
You would use a different ( bigger ) cam with a MR.okk, modified intake as a miniram or just large tube runner with Siamese base?
Bottom line
ZZ4 cam is a good cam used because it is available cheap as a takeout from crate engines but there are better cams
available designed for each different TPI intake if paying full $$$
The purpose and intent has to be defined before a cam, heads, intake or tune can be designed for use together.
A quick Google search will bring up any number of TPI builds with dyno results so there is no need to re-invent the wheel.
Someone else has done the hard work ( be it corporate or private ) to make a working combo.
In my case above, I used the ZZ4 cam in a quicky budget build because it was on the shelf and I had other complementary parts that came together with good results.
Would it have gone better with another cam........?
3.07 gears will get best result for you if you don't already have themjust something with more of a low bottom end torque launch with a lil more mid range.
Ok, ill look into that thank you
how about 3.33 gears? will i be spinning to much
