chevy6673
std rockers or roller rocker arms .for a 400 hp bb thanks for your thoughts
Roller rockers are "free" HP if you don't mind the expense![]()
You'd need NASA-level instrumentation to measure the tiny power increase from the friction reduction; the stock rockers work just fine, and are utterly reliable.
I'd go with BB full roller rockers and studs. Reduced friction and easier adjustments.std rockers or roller rocker arms .for a 400 hp bb thanks for your thoughts
Conversely, add roller rockers to an engine which runs primarily below 6000 rpm, and the difference might be measurable but not much in a practical sense.
looks like factory long slot wins thanks for the thoughtserd:
I agree. But also look at long term durabililty. I'm running factory long slot rockers with the pivot balls that are grooved- also factory parts. Zl-1 factory cam and springs, and have never had a rocker problem. 7/16 pushrods too.
And for the difference in cost between the factory rockers and the rollers what can you do with the extra cash?
