M
Marcel
I use 5W40 because i've got a new motor.
No company with good lawyers would ever gaurantee something like thatXS650 said:If there was absolutly no problem, Mobil could simply had said "If your engine doen't leak now, it won't leak when you switch to Mobil One. " But they didn't because they can't gaurantee that.
Roy said:Why in the world would you want to treat good ole American steel (o.k., cast iron) like it was some wimpey butt imported aluminum 4-banger engine?
So why get your panties in a bunch and worry so much about using exotic and expensive oils when the Chevy V-8 engine was built to run on just about any oil, as long as you change it every now and then. It would be different if you had some sissy engine under the hood that was built to exacting standards and tolerances.
Enjoy the Chevy V-8 for what it is, a fairly big, clunkey, infinately forgiving engine that don't need no extra frilly gizmo gadgets and unnecesary pampering.
