- Moderator
- #1
- Joined
- Nov 9, 2000
- Messages
- 7,520
- Location
- Edgerton, Ohio, United States
- Corvette
- 1959 black 270hp (9/2/69) 1981 Beige L81(10/20/80)
I found a place on the upper right door pillar where there was some rust bleeding out of a crack in the seam sealer. I find that suprising for a car that has never spent any time outdoors setting or ever seen any winter weather. I cut out some of the seam sealer and there was some surface rust on the steel. I need to clean it up and grind out a little of the bonding agent to expose all of the surface rust and get back to clean steel. Once the rust is cleaned off I will need to build up the contour of the bonding agent as original so the door w/strip will seat against it properly again and re-coat with seam sealer.
The funny thing about this is that while searching for a laquer source on the web I found a company in San Diego that sells all types of laquer for restorations; right the middle of the state that outlawed laquer use in body shops first.
Laquer is still available at my local DuPont auto paint store too so that is no problem.
The w/strips are not the best either with 2 pieces needing replaced and some cracking in the others. I think I'll just get the 9 piece set and replace them all.
Has anyone ever used the DuPont Krytox w/strip preservative? I have used other products but I could see that I was loosing the battle several years ago.
I also have to replace the valve cover gaskets again. No rubberized cork this time. (I gave up on RTV lasting any more than a few months years ago) I bought 2 sets of the Super Seal blue silicone with the stainless shim reinforcement when I was doing my stepside 355. I hope these fix the problem for a long time. It seems to be the same material that the Fel-Pro one piece pan gasket is made of that I put on the truck.
So what is everyone else doing this winter?
Tom
Tom
