captainrags
Is it posible to remove and replace or repack all four hubs and bearings. Or do you have to replace complete units.
"Old style mechanic"
Best price on late OEM Delco fronts. Any recommendations as far as brand? Obviously, AcDelco=Pricey,
My rear bearings had 51k with some play so I just replaced with Timken which say "Made in the USA" on the box so hope they are OK.
A friend of mine is replacing his on a 93 at 47k and he found a note in the history that advised replacement at 26k as one had paly in it.
There's a 93 for sale near me that has had new bearings at 50k and a friend of mine with a 90 ZR-1 replaced his at 45k.
All above refer to rear bearings apart from the Z which had all 4 replaced.
My fronts are perfect.
I hope the Timkens last. They seem very well made and have no grease nipples or anything...
Malc
I think the bearings are ball bearings, unlike the tapered bearings in older cars.
Glenn
My rear bearings that were original GM bearings had play with 55,000 miles when I purchased the vette. I would bet it started well before that. I first ordered Timken's and ended up telling AZ to keep them because it said made in china on the box and they were selling at a made in the USA price. I ordered no name rear hubs on ebay and the box and the hubs looked exactly like that from AZ. Part number and date stamps in the identical locations. They installed perfectly, with zero play, and still have zero play after a year. What impressed me most is how handling improved with the new bearing. My local vette shop said to forget what the GM manual states on tolerances and replace at the first sign of any play.I disagree with a good GM bearing going 100K, I have a LR wheel bearing with a little play in it. Not much, but it is there. All others are still good however at 54K. Any recommendations as far as brand? Obviously, AcDelco=Pricey, I have heard that Timken is ok, some of there stuff made in Chine? Wheel Bearings Inc. supposedly is all USA made stuff and reasonably priced.
You get what you pay for, however, if one can get a good product at a reasonable price, well duh...
I put some cheapies on for buddy of mine, his car is nothing but a DD and he got it really cheap. His car doesn't see drag strip launches they way mine does either.
I used be be a mechanic back in the 50/60’s we repaired things then, So regarding the wheel bearing issue that I haven’t really looked at so just for communications sake I know that tapered bearings usually used back then, on front and sometimes rears required repacking but during the process you could inspect the actual case hardening and see if the bearings need to be replaced if they were pitted. In this instance they appear to be sealed ball bearings however are the actual bearings inserted into a aluminum casing eg wheel hub?
If inserted they would more that likely be pressed in, therefore my main question is why can’t the old loose or slack ball bearing be pressed out and a new one pressed in therefore doing a repair not a complete replacement of the entire hub assembly it has to be cheaper???
If you have the right equipment to press them out and in , and the bearings are available , then I see no reason why this couldn't be done. I have actually thought about this often. I would want to inspect the hub very closely after the bearings have been pressed out.Also I think it would be wise to use a cyl retaining compound.
Glenn
