When to do tune up.
ICOMP
Lawrenceburg, IN
2007 Black Z51 Coupe and 2004 Magnetic Red Coupe
My '04 coupe just turned past 50K miles. Outside of regularly schedule oil and air filter changes and chassis lubes. There's never been any engine work and it's still performing well. I am noticing that the engine sometimes hesitates to fire up on the first key turn. Is it time for a tune up, and if so, what needs to be checked?
ernestD
naples fl.
2002 electron blue coupe
I would change the spark plugs first.GM says the factory plugs can last 100k! right!I pulled mine at 50k and they looked fine but worn down.Guess what poor performance,bad gas mileage.Buy a new set.Next check the air filter,if it's dirty,replace it.These car are no different as far as tune-ups go,most people can do them theirselfs.The fuel filter change is harder.Do these things along with your oil and filter changes and you should be good to go!:w
gmjunkie
Old Fort NC/Vero Beach FL
03 Z-51,78 L82 Coupe
My 03 has over 75 on it and runs flawlessly!!I have have had to replace the short rubber nipple on the throttle body for the PCV valve 3 times in 7 years,if it's leaking it can cause your symptoms and others depending the size of the vacuum leak!:thumb:thumb:thumb
I just put the first set of brake pads on the front last week,they still had 1/3 rd the pad left at 75,000 miles!! :beer
ernestD
naples fl.
Hey junkie I just replaced that rubber nipple on the throttle body popped the hood and it was whisteling dixie wtf what causes that? Had a big ol' hole in it!
ICOMP
Lawrenceburg, IN
Sounds like a plan. Thanks...
ICOMP
Lawrenceburg, IN
Just goes to show that the GM engineers know their stuff...It's true, I keep waiting for something to go wrong, but the car just keeps on performing! I love it!
Mr. Lucky
Orange, CA
2004 MY stroker Coupe
Chassis lube on a C5... where?
Toms007
Moderator
Southwest Kansas
2007 Atomic Orange Coupe
Not to hijack, but to expand on what Junkie said. Jesse,
the short rubber nipple on the throttle body for the PCV valve 3 times in 7 years, if it's leaking it can cause your symptoms and others depending the size of the vacuum leak!
I have a little hesitation when I step on the gas, you think this is a possibility? What size hose is it? Is it more like a fuel hose or vacuum hose? The car is up on the lift, so I can't just pop the hood to take a look, but I will check it as soon as I get it on the ground.
ernestD
naples fl.
to Toms01-the hose jnnkie is talking about is the small rubber hose on the pvc valve to the throttle body.If you stand in front of your vette it will be on the left side throttle body.Its a short piece of hose and very thin rubber!Mime had a big hole in it ,I don't know why.It threw a check engine lite every now and then.I'd clear it and in a couple of days it came back!I cut a piece of fuel line hose,thicker,and replaced it,job done!GM parts probly want a million bucks for the factory replacement! goodluck,check yours out:w
