commando57
I have a 1971 LT-1 with the stock transistorized ignition.
8203 with ballast resistor or
8202 without ballast resistor?
(It must be red)
(It must be red)
I believe your 71 w/ TI probably has an original resistor wire (cloth-covered resistor wire) as functioning ballast. My MSD catalog has this to say about the ballast resistor (MSD P/N 8214) that's included with some msd part numbers: "Points ignition systems require this ballast resistor included with this kit in addition to any original resistor or resistor wiring." ... AND ... "With a stock points style ignition, a ballast resistor must be placed in-line with the positive terminal of the coil."commando57 said:I have a 1971 LT-1 with the stock transisterized ignition.
(It must be red)
