M
Macgyver
Ok ok this might be a dumb question for some out there but Im gonna just put it out there anyways.
What would be the problem really w/ using a turbo charger that came off an eclipse like this one:
Mitsubishi turbocharger for the 1989-98 Mitsubishi Eclipse. The Part # is 49178-05200, and the Model # is TD05H-16G. This factory upgrade for the 89-98 DSM cars increases compressor flow by 25% at 505 CFM at 15 PSI boost Supports 340 HP. It has a larger 7CM2 turbine housings for reduced back pressure at high RPM. It is a direct replacement for the first generation TD04H and TD04H turbos. Second generation cars will require the 2G installation kit.
...whatever that means
What would it take to hook this up to a engine w/ a carb? Is it possible?
These turbo kits are like $2K plus installation. Why not find one on ebay or something and convert it. Ive not heard of this before so Im asking the question.
Im saving to buy another engine currently and Ive decided to drive the current one until it blows. Why not have some fun w/ it in the meantime, eh?
