T
Toms88
Yesterday I experienced a sudden onset coolant leak after a short drive. Coolant was literally streaming out at the back of the block between the oil pan and the transmission pan. The leak continued for 5 minutes or so and then more or less stopped. I restarted the car for a few seconds and the same thing happened. I restarted again and pulled up on ramps. After the leak started slowing, I got under the car and it appears the leak originates above the oil filter, under the #7 plug, and in the area of a sensor (?) that is in the block below and to the rear of the oxygen sensor. I admit I am guessing about the location but it's hard to see the area. There is no coolant visible around the intake manifold. Also, there is, I believe, a freeze plug near the above mentioned sensor(?) and the plug seems intact. The engine runs normal, nothing unusual from exhaust, and oil on dipstick looks fine. Any ideas on what I'm dealing with or how to proceed ? Thanks
