More on vacuum/hydraulics
Van at Vanco Power Brake Supply just called, Very helpful!!
We chatted a while and the net is:
"Decide how you will drive the car". (Have I heard that B4?)
"Use a hydraboost for very heavy or very fast cars. The 1-1 1/2" of travel on our brakes pedals would be maximum braking (locked wheels) with the hydraulic booster. They are immediate, like power steering." They also have drawbacks, primarily loss of pressure (brakes AND steering) from failed or slipping belts, bad pumps or stalled engines.
I asked about loss of boost to my steering and he said the PS pump must be rebuilt to deliver more fluid; "a drilled hole and some washers, but done professionally".
They are a small, family owned biz and redo boosters for our cars. He feels they are of low quality and fail rather a lot. The '84 is smaller and delivers a bit less oomph than the later ones.
His recommend to me? Get a Delco electric vacuum pump and see how I like it. They are smart (demand driven) and used on cars such as '80s Caddys and four-banger Skylarks of similar vintage. Junkyard cost whold be very low; new cost is rather low, nuch more than the hydra and the install simple. (VANCO doesn't sell them, BTW.) If I need more brakes, which is doubtful, I can spend the $600 for a hydraboosted setup.
Gawd, I luv guys who have been there, know IT, stand to gain naught, yet tell the simple, unembellished truth. If this works, I may send the guy a C-note thanks you.
mike
