window rattle
S
silverc5
Has anyone had a problem with the drivers side window rattling when all the way down. The only way to solve this problem is to keep window up about a inch or two. I just bought the car on friday july 19th 2002. :confused
rwd
Yes
Varies
Do you mean that you just bought the 1997? Or is there a new C5 involved? I haven't seen any complaints on this particular issue, and IIRC, the most of the window adjustments are fairly accessible. The only frequent noise I can recall from that area is the seat belt hitting the door while in its retainer.
L
les
I've had a problem with my driver side window since I bought the car in 1999. It's been to the dealer 2 times , so far.
S
silverc5
We just bought the 97 and noticed the rattle on the second day. I just wanted to know if anyone currently has or had the same problem and if they were able to get it fixed.
c4c5specialist
Technical Advisor
New Haven, Ct. USA
Nope, but someday.
HI there,
There are a few bulletins for inner door rattles from the regulator assemblies.
First, 83-15-05 is for a door rattle, and you would have to install an insulator in the door.
The second, is 00-08-64-004, which is for a noisy regulator movement, or inoperative condition.
Either of these 2 bulletins can be referenced for your concern.
Besttoyou, c4c5:hb
L
les
Thanks c4. Got that printed and it's going to the dealer with me.
Site Administrator
Staff member
Administrator
New Hampshire
1990 Corvette ZR-1
