window slipping
joe1975
Louisiana
1975 Orange L-82 4 Sp.
My pas. side window goes up all right but then it slips back down a 1/4 inch or so any ideas or fixes?:confused
The bolts that hold the window assembly to the door frame can get loose after a while. Pull the interior panel and see if it has come loose. The whole assembly is held in by four 1/2" head bolts that are in oversized holes and can slip out of position if loose, but can easily be readjusted by pulling the window up all the way, and re tightening the bolts.
Thanks for the input something I will check out
