J
jmp
I pulled my windshield off because of a leak and a small rust hole at the top of the windshield, and discovered more rust at the bottom of the frame. This seems to be a common problem, and the solutions I've been hearing are making me lose sleep at nights!
I'm not sure how bad the problem is. I don't have water leaking onto my feet, and the leak at the top only occurs in heavy rain. But the lower part of the windshield frame is quite rusted out.
Questions:
1) Is this structural damage or more simply a problem with water flow control as rain water runs down the side of the windshield and onto the road?
1a) The reason I ask is: can I clean up the rust and just fibreglass over the holes, or do I need to get a patch welded on?
2) If I take the console out, can I get to the underside of this frame damage?
3) If I can't get to the underside and I need to weld, is cutting back the front fender the only/best/easiest way to go, or would removing the front clip be better/easier/cheaper? Cutting seems so severe.
I've attached some pics to demonstrate.
On a side note, where does the draining water actually go? It disappears into a dark hole and I'm not sure where it ends up. It almost sees as if it would spill out onto the door hinges.
Thx.
Questions:
Thx.
