When I turn on the windshield wipers n my 85 they won't turn off until I shut the car off and then when I turn the key on they park. Any idea what is going on? Also while I am asking does anyone know where the speed sensor for the cruise control is?
I would think it is in the switch. It is something that I have never encountered before. Did you try doing a search? Maybe somebody else had this problem.
I dont know if there is a relay that actually powers the motors, but I would suspect there is. I guess that might be the cause for some problems. I am not familar with the wiring for that part of the car. Do you have any manuals for the car? I will check what I have, but I am still waiting for the Helm manual.
I actually looked on ebay first & found an entire wiper motor out of a wrecked 94 & got cover & wiper motor for $35.00, but you take the chance of having the same problem. I contacted the seller first & he promised it worked fine & would refund my money if it didn't.
Either way you go I believe your problem is in the cover.
No problem. Glad I could finally help someone else for a change.
What part of Pa. are you in? I'm from the Lock Haven area.
Good luck fixing the problem. The cover board isn't hard to change but the bottom torx screw is a bit tough to get to. After changing the cover on mine wipers work fine.
I was able to get at mine with a 1/4 inch rachet & extension witha torx socket for the top & 2 side screws. The bottom screw I ended up using a torx head bit like the changable type that would go in a screwdriver handle & a small 1/4 inch wrench on the bit. After many small turns & a few choice words I was able to get the screw out & back in.
