jrogensk
Active member
A while ago I replaced the wiper blades with Anco blades (the entire blade, not just the inserts). Shortly afterward I noticed that the hood was catching the top of the arm when I turned the wipers on or off. I tried adjusting the hood but it is at the end of the adjustment range and still catching the wipers. It is also very noticable that the hood is sitting too high.
Unfortunately I tossed the originals after I replaced them. Is there an aftermarket brand that will fit properly or do I need to go back to the original style?
