H
hdjpcp
Greetings,
Would someone please tell me what wires should be connected to the starter/solenoid and at which posts on my 72 with 350/TH-400?
I have the positive cable from the battery to the center solenoid post along with a red wire, presumably ignition. I have a purple wire that comes to the left terminal of the solenoid (as you face the installed starter from the front of the car). A yellow wire with black markings comes off the right side of the solenoid. I have no ground from starter to ground.
The starter doesn't engage. I suspect something is missing, either a ground or something isn't connected where it should be. Lacking a wiring diagram, I'm hoping someone here can help.
Thanks.
Thanks.
