jeffn
A stock 79' L-82 w/ 42k miles.....If I replace the original water pump with a Stewart high flow water pump, Is anything bad going to happen with the stock cooling system ? Should I just get an identical replacement part ?
That being said, will the Stewart "open the car up " a bit...?...For a stock car there isn't much I can do to help it "breath easier" other than exhaust and cooling modifications, w/o going nuts and getting into the heads and motor, which I'm not going to do.This is a 1000k/yr driver...Not a show car or a race car, but I'd like to improve the performance a bit.....Any little tricks out there?....Do tell.;squint:
