Twin_Turbo
- Joined
- Jan 11, 2001
- Messages
- 618
- Location
- Enschede, The Netherlands
- Corvette
- 1982 Twin Turbocharged Red/Black
The stock stamped rockers are actually only about 1,48:1 .
If you use 1,6 rockers the valve lift increases and if you have a high lift cam you might have problems with either valve to piston clearance of the valve springs binding (which will result in wibed lopes, broken springs, bent pushrods.. .not good
If you have the stock L82 cam you can run the 1,6 rockers, no problem. Just watch the geometry and the motion of the (roller) tip over the valve stem and make sure that in all it's travel the roller never goes on or over the side. It's all in correct pushrod size. Normally this won't give any problems.
