1966 Corvette help please
robgoodrich
New member
Bayfield, Colorado
1966 Silver Pearl/sliver convertible
Hi,
I have a '66 convertible and am trying to remove the two metal sleeves that cover the steering column. I have removed the top one, but am having trouble removing the lower (somewhat conical) sleeve. I did the easy stuff, removed the turn signal stalk, removed the 3 screws that hold the white plastic piece, loosened the collar and the other metal piece that attach to the bottom of the instrument panel. Loosened the wiring harness so it can slide, but it does not want to slide up with the sleeve.
Hope you can follow this and give me some advice. I want to get the two sleeves repainted.
Thanks,
Toms007
Moderator
Southwest Kansas
2007 Atomic Orange Coupe
Rob, I believe a welcome is in order. :w As for the problem removing the collars...I'm thinking it's time to give up and just give that ole piece of junk 66 Corvette to me. :D I think it must be too much work, that it's not worth the effort. Heck, I'll even come pick it up for you.......
In reality, we have some really great guys who'll be able to help you get things done. (thinking the whole column probably needs to come out, but I'm probably wrong)
bill81vette
Moderator
Troy,NY
1981 dark blue metallic
Welcome to CAC!!!!
enjoy!!!`
Site Administrator
Staff member
Administrator
New Hampshire
1990 Corvette ZR-1
Moving out of the Site Help and Feedback forum and into the C1/C2 Forum...
Toms007
Moderator
Southwest Kansas
Didn't even realize where it was, Rob. Thanks for the move.
