1970 vette battery drain
dalebenz
janesville
1970 rd 1968dark green
when i pull the clk,litr,ctsy fuse ,which is the upper left fuse,. the draw goes away.any body no what all goes on that fuse,Ive pulled the liter,all 3 courtesy lamps,radio,clock.and glove compartment light
gmjunkie
Old Fort NC/Vero Beach FL
03 Z-51,78 L82 Coupe
How big of drain?
dalebenz
janesville
Idont know but a 12 volt tester lights up when i connect between the neg post and the neg cable
gmjunkie
Just about any vehicle will do that,You need to test the drain with a VOM.
stevolwevol
Michigan
1977 light blue
One place to check is your spare tire area. There is a light bulb that could be on, but you can't see it till you remove your spare.
dalebenz
janesville
i understand ,if key is out of ignition,no switches on, radio off,courtesy lights off, emer brake off,doors closed,all accessories off,lighter out,clock disconnected ,glove box light disconnected their should be no parasitic battery drain between neg cable and neg post but I do.I have no light back by the spare tire area
Portage, Indiana
2010 Grand Sport Vert JS Blue
Disconnect the alternator from the system, when I was at a GM garage I saw many bad diode-trios cause a drain.
Tom Bryant
Administrator
Edgerton, Ohio, United States
1959 black 270hp (9/2/69) 1981 Beige L81(10/20/80)
I forgot about that. Diode Trios went across the parts counter almost as fast as brush sets and ignition points back then.
Tom
gmjunkie
Problem with the diode trio would be pulling the
clk,litr,ctsy fuse wouldn't change the drain. Alt is on a different circuit.
Win Both Corvettes!
Win Both Corvettes and Get Extra Bonus Tickets Now!
Dead Center Foundation
