ELectrical issues usually are difficult for me. My question is about the seatbelt interlock switch that if I am not mistaken is exclusive of the 1974 model year.
After 4 years of working on my frame off of my 74 convertible I have the body on and am very close to being ready to start the Engine. I am trying to get to the point where I know that I have ignition. I have tried to turn the engine over but have not had any luck getting the starter to turn. Here is what I have done so far.
1. Hooked up harness that goes to the Starter. My manual Haynes says that the wiring connections are determined by the size of the connector matched to the size of the lug.
2. Battery Ground is connected w/ good ground to frame.
3. All of the enbgine compartment wiring is connected with the exception of a couple of plugs under the brake booster that I cannot Identify. And the yellow wire that I assume to be the positive to fusebox from starter? Does the positive juice for the car originate at the starter through this wire? I have tried connecting it to the lug at the starter + side and still do not get ignition.
4. I have connected the coil to the wires that are associated with it. The question that I have concerning the coil wiring is about the +/- terminals. My service manual does not differentiate between the pos / neg. Does it matter how the wires are connected? I have the black wire from the bottom of the distributor connected to the pos side and the wire from the resister or whatever that thing is that is connected to the side of the coil mount attached to the neg side.
This has been long winded and I hope that I have described my situation properly.
The question I have finally concerning the seatbelt interlock switch under the seats. Do I need to have that entire system connected before I will get ignition?
Appreciate your responses.........................Mike..........Utah
