- Thread starter
- #21
G
Granpooba
Yeah,I have allot of Ideas!:L
But you probly won't like'em!!:L
I need more information!!
Are we using Real R-12??
Are we using Johnsen's Freeze-12??
And what kind of Pressures are we running,High Side /Low Side??
(When the compressor is running!)
What is the Humidity??
What is the Ambient Temp??
What is the Engine Coolant Temp??
Are all the Air Deflectors in place around the Radiator and Condenser??
Is your Radiator and Condenser free of deb're??
Is the Evaporator free of Lint,Leaves,Mouse Nests,or other obstructions??
What is the AC Discharge Air Temp when it runs before it go's Hot??
What is the Low Side pressure when the Compressor shuts down??
What is the High Side pressure when the compressor shuts down??
Hmmmmmmmmm ........ you must think that I am a rocket scientist !!
Nope, just a retired Corporate Pilot.
My Vette is completely stock all original, except it was converted from R-12.
Considering the fact that I do not have all the tools or knowledge to work on this problem and that I am due for an oil/filter change/State Inspection.
I have made an appointment with our local Chevrolet dealership, who has a decent Vette mechanic. I have asked them to diagnose the AC problem and advise me of what is causing this problem. Not authorizing them to make the fix, just check it out.
I feel that this is the easier route to follow, rather than answering all those questions !! :L
Will let you all know what is found ...... and thanks for all of your input.
