chris123
On my 1986 Convertible 4+3 manual, I used the Factory Service Manual to trace down an inoperative cooling fan, and I've found out the there is no power to the red wire (Terminal "E") going into the fan control relay, so it looks like the fusible link is bad that is supplying power to the relay; I was able to get the fan to run when I installed a temporary fused wire directly from the battery to the red wire going into the relay; my question is what size/rating fusible link do I get to replace it? I couldn't find it anywhere in the manual; also, can I pick one up at Pep Boys, Autozone, etc.?
Thanks, Chris
Thanks, Chris
